11axTWT
The IEEE 802.11ax standard defines power saving enhancements and improved resource scheduling features including scheduled sleep and wake times. The Target Wake Time (TWT) option allows devices, APs and stations, to negotiate when and how frequently they will wake up to send or receive data. TWT increases device sleep time, thereby substantially improving the client device's battery life.
Use this command to enable 11ax TWT support on the radio. TWT is disabled by default.
Syntax
11axTWT
Parameters
None
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axTWT
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context
 interface radio1
  11axSupport
  11axOFDMA both
  11axTWT
  11axBSScolor 20
Related Commands
no (radio-interface-config-command) Disables 802.11ax TWT support on the selected radio
